Los fierros del estudio de David Gilmour
7 mensajes
En esta extensa nota, el ingeniero de grabación habla desde la importancia de las tomas eléctricas hasta los monitores ATC que usan en el estudio, que según él son los mejores....
http://www.davidgilmour.com/press/2005/ ... arch05.pdf
- Porquenoanda
Re: Los fierros del estudio de David Gilmour
Esta bueno, no lo habia leido
Esta parte no me termina de convencer mucho que digamos jeje
What was the difference that you heard?
A difference in clarity, I suppose. One way it sounded a little middle-ier, and a little more distorted
than the other direction. Anyway, back to audio cable. We went though all these regular cables that
people wire studios up with that are fairly inexpensive. And the one that we ended up using was
made by - this is for the 23 kilometers of cabling - was made by a high end hi-fi audio manufacturer
called Van den Hul from Holland. I’d actually later found out they had originally designed this cable
for the Philips Studio in Holland. Now because they had a lot of stock on the shelf, ready to go, I was
able to negotiate a terrific deal. It only cost five times more than a regular cable would cost. But it
was worth it. It was our one chance.
Can we talk about AC power? I know you have given a lot of thought and effort to power on
the Astoria.
We realized many years ago the AC power, the mains as I call it, can make an incredible difference
to the sound, to the audio. Most people, or a lot of people, are unaware of that. They think that if you
plug something in and it lights up, fine, it works, with no conception that it could sound different.
the Astoria.
Se gastaron toda la joda boludeando con los cables, con razón el disco es un embole.. [emoji38]
<< Sent using Tapatalk >>
Y de tantos auriculares...a Gilmour se lo ve usando unos simple Sony en un video....
Muy interesante el artículo...
El gordo siempre me encantó cómo toca, pero su sonido de los últimos años nunca me terminó de convencer...
Guarda que en el dvd doble que saco el de Polonia, no me acuerdo
el nombre, en el dvd 2 hay tres temas al final de una jam, suenan de c@&@$a madre
inclusive esta mezclado con video de la produccion del tema donde se muestran
los equipos que se usaron.
SALUDOS
SALUDOS
7 mensajes
