PARLANTES MONITOR AUDIO LÍNEA GOLD - GS10 - EN SU CAJA
por Alberto Raul » 29 Mar 2018, 10:22
Vendo
Par de Parlantes [size=150]MONITOR AUDIO LINEA GOLD MODELO GS10[/size]
En su Caja y con todos sus accesorios.
COLOR Negro . Laqueado Tipo Piano
Son INGLESES
Entrega inmediata.
Luego pondré las especificaciones técnicas.
De verdad es para aprovechar . Dificil encontrar algo asi. De esa calidad y estado.
Lo garantizo 100%.
Cualquier consulta quedo a disposición.
USD 2.190.-
Alberto Raul
por Alberto Raul » 01 Abr 2018, 13:11
VENDO
PAR DE SPEAKERS
MONITOR AUDIO GOLD SIGNATURE - GS10
DETALLES:
The GS10 re-writes the book on compact monitor performance, easily eclipsing the dazzling standard set by its predecessor, the GR10.
It may be small, but the GS10 showcases the multiple talents that make the Gold Signature series so remarkable. With its advanced, low-resonance drivers, rigid build and contoured cabinet edges, the GS10 redefines accurate, low-colouration sound in a compact, stylish stand-mount speaker.[/size]
Using the new, low distortion 6 1/2” RST II bass-mid driver and gold C-CAM tweeter developed especially for the GS series, the GS10 is capable of true 3-D imaging and tonal accuracy.
Technology
Anti-resonance build: driver held by innovative zinc alloy clamp system; traditional tongue and groove construction; extensive vertical and radial internal bracing
6 1/2" die-cast aluminium chassis bass and bass-mid drivers featuring a new Rigid Surface Technology RST®II, C-CAM® alloy cone profile
A new 1” C-CAM Gold Dome tweeter extends high frequency performance extends to between 30Hz - 45kHz
HiVe®II port design: the new port technology uses a straight rifled construction to aid air flow and reduce turbulence
Bespoke stands: for the GS10 and GSLCR with a die-cast alloy base (as GS20) and cable management for a neater finish
Frequency Response
40 Hz - 45 KHz
Sensitivity (1W@1M)
88 dB
Nominal Impedance
8 Ohms
Maximum SPL
108 dBA
Power Handling (RMS)
100 W
Recommended Amplifier Requirements
40 - 100 W
Bass Alignment
Ported Bass Reflex (HiVe II Technology)
Crossover Frequency
2.7 KHz
Drive Unit Complement
1 x 6" RST II bass/mid-range driver
1x 1" (25 mm) C-CAM Gold Dome tweeter
External Dimensions (H x W x D)
360 x 206 x 270mm
(143/16 x 81/8 x 105/8 inch)
Weight (each)
8.5 kg (18.7 lb)
USD 2.190.-
Alberto Raul
por Alberto Raul » 07 Abr 2018, 14:41
CUALQUIER CONSULTA QUEDO A DISPOSICIÓN
ES LA LÍNEA GOLD SIGNATURE. DISEÑADO Y FABRICADO EN INGLATERRA Y EN SU CAJA
USD 2.150.-
Alberto Raul
por Alberto Raul » 14 Abr 2018, 13:20
PARA MEJORAR LA OFERTA Y LA EXPERIENCIA en vez de hacer un <UP>
:-D AGREGO PAR DE PEDESTALES EN MADERA Y ALUMINIO QUE SON EXCELENTES!
EN CUANTO A LOS MONITOR AUDIO GS10:
USD 2.150.-
Alberto Raul
Alberto Raul
por Alberto Raul » 15 Abr 2018, 10:27
Si quieren verlos quedo a disposición
SON REALMENTE EXCELENTES!
Alberto Raul
por Alberto Raul » 22 Abr 2018, 13:48
INCLUYO PAR DE PEDESTALES EN MADERA Y ALUMINIO QUE SON EXCELENTES!
ES "LA LÍNEA GOLD SIGNATURE".
USD 2.090.-
Alberto Raul
Alberto Raul
por g3tokio2005 » 23 Abr 2018, 03:23
Alberto Raul escribiste:INCLUYO PAR DE PEDESTALES EN MADERA Y ALUMINIO QUE SON EXCELENTES!
USD 2.090.-
Alberto Raul
Busco los Monitor Audio Gold 100, excelente parlantes los q vendes, suerte con la venta
Enviado desde mi HTC 10 mediante Tapatalk
g3tokio2005
por Alberto Raul » 23 Abr 2018, 22:54
Muchas gracias g3tokio2005!!!!
Si. Realmente son un LUJO
Y me gustaría de verdad que queden en el FORO!
Alberto Raul
por Alberto Raul » 28 Abr 2018, 12:26
SON "LA LÍNEA GOLD SIGNATURE" LOS FLAGSHIP DE LA MARCA
DISEÑADOS Y FABRICADOS EN INGLATERRA Y EN SU CAJA
Si alguien quiere que le mande fotos sin problemas lo haré
USD 2.050.-
Alberto Raul
Alberto Raul
por Alberto Raul » 05 May 2018, 13:18
USD 1.999.-
Alberto Raul
  • Hasy 4 Usuarios identificados :: 0 registrado, 0 ocultos y 4 invitados (basados en usuarios activos en los últimos 5 minutos)
  • Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 4 invitados
