BOSE SoundLink MINI - IMPECABLE - COMO NUEVO
5 mensajes
- Alberto Raul
VENDO
IMPECABLE POR DONDE SE LO MIRE
PRÁCTICAMENTE SIN USO.
CON SU CAJA Y TODOS LOS ACCESORIOS
COLOR PLATEADO
Product Description
Enjoy better sound on the go, everywhere you go, with the Bose Sound Link Mini Bluetooth speaker. It delivers full, natural sound from an ultra-compact speaker that fits in the palm of your hand. The speaker connects wirelessly to your smartphone, tablet or other Bluetooth device. A lithium-ion battery gives you hours of unplugged play time. And the included charging cradle keeps the speaker fully charged while serving as its convenient home base. The Sound Link Mini speaker is engineered with a solid, aluminum housing and skid-proof rubber bottom, so it can stand up to everyday use. Take your music, videos and games places they've never been before.
Advanced audio performance delivers full-range listening experience
The most compact mobile speaker from Bose easily goes where you go
Wirelessly connects to your Bluetooth device
Lithium-ion battery provides up to 8 hours of playing time
Ultra-compact. Wireless. Better sound.
Enjoy your music on the go, everywhere you go. The SoundLink Mini Bluetooth speaker delivers full, natural sound from an ultra-compact speaker that fits in the palm of your hand. It connects wirelessly to your smartphone, tablet or other Bluetooth device, so you can listen to your music, videos or games anytime, anywhere. Just grab it and go.
Plays where you play
Bose SoundLink Mini Outside
Enjoy your music and videos in full-range sound just about anywhere. Grab it and go.
The SoundLink Mini speaker is small and light enough to tuck into your bag. It weighs in at just 1.5 pounds. Its low profile lets you place it almost anywhere and provides a low center of gravity that makes it nearly impossible to tip over.
The rechargeable lithium-ion battery delivers up to 7 hours of playtime. And at home, you can listen even longer-—the charging cradle lets you listen while it charges. An empty battery usually fully recharges in three hours.
Bluetooth Connectivity
The speaker has a range of about 30 feet, so you can enjoy the sound you want without wires. It pairs easily with your smartphone, iPad or other Bluetooth devices. And it remembers the most recent six devices you've used, so reconnecting is even simpler.
Big performance, small size
You might not expect sound this rich from a speaker this small, but the SoundLink Mini speaker is something new. You don't have to sacrifice performance for portability. Proprietary technologies and an innovative driver configuration combine to deliver full-range sound—-including deep lows-—in an ultra-compact package. It lets you take your music to places it's never been before.
Easy operation, elegant design
Bose SoundLink Mini Devices
The SoundLink Mini speaker is designed for sleek simplicity. Its single-piece aluminum casing is both attractive and durable. The speaker features power and volume buttons—-you control all other functions from your Bluetooth device.
Additional Features
Charging cradle recharges the battery and serves as a convenient home base for your speaker, and it lets you play while it charges.
Wall charger can be plugged into the cradle or directly into the speaker.
Auxilary port lets you connect other audio sources, like an MP3 player.
USB port allows for software update to ensure ongoing Bluetooth device compatibility.
3.990.-
(ENTIENDO QUE CASI LA MITAD DE LO QUE SE VENDE EN NEGOCIOS)
COLOR PLATEADO
Product Description
Additional Features
3.990.-
- Alberto Raul
Re: BOSE SoundLink MINI - IMPECABLE - COMO NUEVO
NUEVO PRECIO
$ 3.490.-
$ 3.490.-
- Alberto Raul
$ 3.290.-
Para ver si queda en el Foro...
- Alberto Raul
Señores por ahora lo retiro de la venta.
Cosa increíble, ya que siempre guardo las Cajas de Todos mis equipos, en este caso no puedo encontrarla.
Debe estar pero no sé dónde.
Con tiempo buscaré mejor Y allí lo ofrecere nuevamente.
Muchas gracias
Alberto
Muchas gracias
Alberto
- Alberto Raul
Finalmente se vendió y quedó en el Foro.
Muchas gracias Herman!
Y gracias por el espacio
5 mensajes
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 39 invitados
