Oppo Sonica DAC
39 mensajes
• Página 1 de 4 • 1, 2, 3, 4
Oppo Sonica DAC
Hola a todos. Vendo mi Oppo Sonica DAC.
Un excelente aparato para disfrutar la musica de alta calidad.
El motivo de la venta es porque viajo en noviembre y voy a traer otro para mi.
El aparato esta como nuevo, con caja, manual, cable de corriente y control remoto. 220V
Precio 32000$
SPECIFICATIONS
Designs and specifications are subject to change without notice.
General
Dimensions (W x H x D) 10.0 x 3.0 x 14.2 inches, 254 x 76 x 360 mm
Weight 10.4 lbs, 4.7 kg
Power Supply AC 110-120 V ~ / 220-240 V ~ 50/60 Hz
Power Consumption 30 W (operation), 0.5 W (standby)
Trigger Input 3.5 V - 15 V, 10 mA minimum
Trigger Output 12V, 100 mA maximum
Operating Temperature 41°F - 95°F, 5°C - 35°C
Operating Humidity 15% - 75% No condensation
USB Audio Input (USB B Type)
Input Format Stereo PCM, Stereo DSD (DoP v1.1 or native)
PCM Sampling Frequencies 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz, 352.8 kHz, 384 kHz, 705.6 kHz, 768 kHz
PCM Word Length 16-bit, 24-bit, 32-bit
DSD Sampling Frequencies 2.8224 MHz (DSD64), 5.6448 MHz (DSD128), 11.2896 MHz (DSD256), 22.5792 MHz (DSD512, native mode only)
Profile USB 2.0, USB Audio 2.0
Coaxial and Optical Digital Audio Inputs
AUX Audio Input
Input Impedance 10k Ohm
Maximum Input Level 2 Vrms
USB Ports (Type A)
Profile USB 2.0, mass storage only
Audio Format Support AAC, AIF, AIFC, AIFF, APE, FLAC, M4A, M4A (Apple Lossless) ALAC, OGG, WAV, WMA, DSF, DFF
Maximum Sampling Rate PCM up to 192 kHz / 24-bit, DSD up to 2.8224 MHz (DSD64)
Wireless Standard
Wi-Fi 802.11.a/b/g/n/ac
Bluetooth Bluetooth 4.1
DAC Performance Specifications
Specification XLR Output RCA Output
Output Level 4±0.4 Vrms 2±0.2 Vrms
Frequency Response 20 Hz - 160 kHz (+0/-2.4 dB)
20 Hz - 20 kHz (+0/-0.04 dB) 20 Hz - 160 kHz (+0/-2.4 dB)
THD+N at 1 kHz (A Weight, 20 Hz- 20 kHz) < -115 dB < -115 dB
Channel Separation > 120 dB > 120 dB
Signal-to-Noise Ratio
(A Weight, 20 Hz- 20 kHz) > 120 dB > 120 dB
Dynamic Range
(1 kHz -60 dBFS, A Weight, 20 Hz- 20 kHz) > 120 dB > 120 dB
Precio 32000$
SPECIFICATIONS
General
AUX Audio Input
USB Ports (Type A)
Wireless Standard
Dynamic Range
Re: Oppo Sonica DAC
Fotos
Enviado desde mi RS988 mediante Tapatalk
- Sonido Optimo
Re: Oppo Sonica DAC
Mmmmmm.... ando con ganas de uno de éstos pero se me superponen funciones con el equipo que tengo actualmente.
Me gusta la idea de tenerlo todo unificado en un solo equipo.
Voy a estudiarlo.
Voy a estudiarlo.
Sonido Optimo
HT
Marantz 7007
St
Pre Mcintosh C49
Potencia Mcintosh Mc 152
Triode Trv 35ser
Fuentes
Oppo 105D
Blue Sound Node 2
Lenco L75
Spk
F: Monitor Audio G200
R, Up y RM B&W
C: Kef T101c
Tv
Samsung 8550 55" 4k
HT
Marantz 7007
St
Pre Mcintosh C49
Triode Trv 35ser
Fuentes
Oppo 105D
Blue Sound Node 2
Lenco L75
Spk
R, Up y RM B&W
C: Kef T101c
Tv
Samsung 8550 55" 4k
Re: Oppo Sonica DAC
Ningun problema, si queres podes venir a escucharlo para ver las funciones, la calidad etc. Sin compromiso, por supuesto.Sonido Optimo escribiste:Mmmmmm.... ando con ganas de uno de éstos pero se me superponen funciones con el equipo que tengo actualmente.
Voy a estudiarlo.
- fedefilipo
Re: Oppo Sonica DAC
Acepta Spotify, tidal, USB con archivos flac? Gracias
Re: Oppo Sonica DAC
Hola Fedefilipo, si podes usar spotify, tidal, y reproduce archivos flac y muchos formatos mas por USB. Cualquier otra pregunta estoy a tu disposicion.fedefilipo escribiste:Acepta Spotify, tidal, USB con archivos flac? Gracias
Re: Oppo Sonica DAC
Gente, es simple. ¿Buscan un streamer de referencia a precio terrenal y como nuevo? Lo encontraron.
Re: Oppo Sonica DAC
Nippur Audio escribiste:Gente, es simple. ¿Buscan un streamer de referencia a precio terrenal y como nuevo? Lo encontraron.
Gracias Matias.
Re: Oppo Sonica DAC
No entiendo como aùn no lo vendiste..!!!!
Es un caño, suena increible, la aplicación trae nativos Spotify + Tidal... ademas maneja discos en red o bien conectados via usb.
También tiene la posibilidad de acceder por Bluetooth y TODAS esas funciones que detallo se maneja desde la Aplicación.. que la podes tener en IOS o Android... encima es tuyo que sos super cuidadoso con todas tus cosas.
A no dejarlo pasar.
A no dejarlo pasar.
39 mensajes
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 41 invitados
