VENTA ~ DENON AVR S900W ~ Receiver 5.1
por eledus » 21 Nov 2017, 11:40
DENON AVR S900W
AUDIO
Amplifier Output Details 90 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.08% - 7 channels
125 Watt - 6 Ohm - at 1 kHz - THD 0.7% - 7 channels
POWER DEVICE
Nominal Voltage AC 120 V
Frequency Required 60 Hz
Power Consumption Operational 460 Watt
Power Consumption Stand by 0.1 Watt
AUDIO SYSTEM
Type AV network receiver
Subcategory AV components
Functions AV network receiver, amplifier, digital player, internet radio
3D Technology Yes
Media Content Source Network, USB-host
Audio Formats AAC, AIFF, ALAC, DSD, FLAC, MP3, WAV, WMA
Photo Formats JPEG
Sound Output Mode Surround Sound
Audio D/A Converter 24bit / 192kHz
Built-in Decoders DSD decoder, DTS 96/24, Dolby Digital EX, Dolby Digital Plus, Dolby Pro Logic II, Dolby Pro Logic IIx, Dolby Pro Logic IIz, Dolby TrueHD, DTS Express, DTS Neo:6, DTS decoder, DTS-ES Discrete 6.1, DTS-ES Matrix 6.1, DTS-HD High Resolution, DTS-HD Master Audio, Dolby Digital
Surround System Class 7.1 channel
Digital Sound Processor (DSP) Yes
DSP Presets All Ch Stereo, Jazz club, Matrix, Mono Movie, Rock Arena, Video Game, Virtual Surround
Additional Features Apple AirPlay support, Audio Return Channel (ARC), high-pass filter, iPod/iPhone ready, low-cut filter, smartphone remote controlled, upgradeable firmware, x.v.Color, Audyssey Dynamic EQ, Audyssey Dynamic Volume, Audyssey MultEQ, Deep Color, Pure Direct mode, auto sound calibration, compressed music enhancer, dual-zone capability
Bass Control Yes
Treble Control Yes
Built-in Clock sleep timer
HEADER
Brand Denon
Product Line Denon AVR
Model S900W
Packaged Quantity 1
MISCELLANEOUS
Color black
Color Category black
EQUALIZER
Equalizer Yes
Equalizer Type digital graphic
Equalizer Band Qty 9 bands
Equalizer Center Frequencies 1000 Hz, 125 Hz, 16000 Hz, 2000 Hz, 250 Hz, 4000 Hz, 500 Hz, 63 Hz, 8000 Hz
AMPLIFIER
Input Impedance 47 Ohm
Input Sensitivity 200 mV
AMPLIFIER OUTPUT DETAILS
Output Power / Channel 125 Watt, 90 Watt
Output Impedance / Channel 6 Ohm, 8 Ohm
Frequency Response 20 - 20000 Hz, at 1 kHz
Total Harmonic Distortion (THD) 0.08 %, 0.7 %
Channel Qty 7
RADIO
Tuner Type digital
Tuner Bands AM/FM
Tuner Frequency Range AM: 520 - 1710 kHz, FM: 87.5 - 107.9 MHz
Preset Station Qty 56
Additional Features Auto Store (AS), station naming
NETWORK & INTERNET MULTIMEDIA
Functionality Internet radio playback, digital audio playback, digital photo playback
Network Protocols Supported DHCP
Connectivity Interfaces Bluetooth 2.1 EDR, IEEE 802.3 (Ethernet), IEEE 802.3u (Fast Ethernet), Wi-Fi
Internet Streaming Services Flickr, Pandora, SiriusXM internet radio, Spotify, vTuner
DLNA Yes
AUDIO SPECIFICATIONS
Type Amplifier, Radio tuner
Frequency Response 10 - 100000 Hz, at 1 kHz
Signal-To-Noise Ratio 100 dB, 70 dB
Total Harmonic Distortion 0.7%
SIGNAL PROCESSING FEATURES
HDMI Pass-Through up to 4K
Video Conversion/Scaling analog to HDMI up conversion
3D Pass-Through Yes
Upscaling via HDMI up to 4K
CONNECTIONS
Type AM antenna, FM antenna, component video input, component video output, composite video input, headphones, speakers output, subwoofer output, HDMI input, HDMI output, LAN, SPDIF input, USB, audio line-in
Qty 1, 2, 4, 7
Connector Type 19 pin HDMI Type A, RCA x 3, RJ-45, TOSLINK, banana/spade x 2, click-fit x 2, phone stereo 6.3 mm, 4 pin USB Type A, IEC connector, RCA, RCA x 2
Connector Location front, rear
DIMENSIONS & WEIGHT
Width 17.1 in
Depth 13.3 in
Height 6.6 in
Weight 21.38 lbs
Upscaling via HDMI Up to 4K
HDMI Pass-Through Up to 4K
Video Conversion/Scaling Analog to HDMI up conversion
GENERAL
ManufacturerDenon
Lo compre 0km en EEUU y es 110v. el equipo funciona muy bien pero de sus entradas HDMI tiene 1 que no funciona, intente hacerle un reset de fabrica pero no levanta, no se si habrá algún otro método para probar.
Se entrega en Capital Federal con su respectiva caja, manual, antena, micrófono y control remoto.
$ 9000
eledus
por eledus » 21 Nov 2017, 14:29
De apurado puse mal el titulo, es 7.1
eledus
por PLEOMAX » 21 Nov 2017, 15:19
Suerte con la venta, hermoso receiver!!
PLEOMAX
por eledus » 21 Nov 2017, 17:35
PLEOMAX escribiste:Suerte con la venta, hermoso receiver!!
Gracias Alberto.
Enviado desde mi HUAWEI RIO-L03 mediante Tapatalk
eledus
por eledus » 06 Dic 2017, 21:49
Up !!!
eledus
por eledus » 13 Dic 2017, 13:33
eledus
por PLEOMAX » 13 Dic 2017, 19:00
ya que estamos una consulta como te conectas a Spotify x ejemplo con este equipo?
PLEOMAX
por eledus » 13 Dic 2017, 22:30
PLEOMAX escribiste:ya que estamos una consulta como te conectas a Spotify x ejemplo con este equipo?
Hola Alberto como andas?
Spotify es nativo en este equipo así que lo seleccionas por menú y Tidal lo uso a través de un Chromecast por la entrada óptica. Los dos los manejas después con el celu o tablet a través del wifi
Edu
eledus
Edu
eledus
por eledus » 14 Dic 2017, 08:48
Te copio Alberto como esta en el manual del sinto:
Reproducir música de Spotify con esta unidad
Descargue el “Spotify App” en su dispositivo Android o iOS de antemano.
Para reproducir una pista de Spotify en esta unidad, tiene que registrarse antes en la cuenta Spotify premium.
1 Conecte la configuración de Wi-Fi del dispositivo iOS o Android en la misma red que esta unidad.
2 Inicie el Spotify App.
3 Reproduzca la pista de Spotify que desee reproducir con esta unidad.
4 Toque el icono SpotifyConnect para seleccionar la unidad.
La música se enviará a esta unidad.
eledus
  • Hasy 4 Usuarios identificados :: 0 registrado, 0 ocultos y 4 invitados (basados en usuarios activos en los últimos 5 minutos)
  • Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 4 invitados
