Vendo Reproductor Astell & Kern Ak120 64gb + Dock + Rc
por dariohead » 08 Ene 2018, 22:53
Estimados, estoy vendiendo este tremendo tanque con dual DAC Wolfson WM8740. Es un reproductor de alta definicion Astell & Kern, modelo AK120.
Lo suelo usar con el volumen al 55%, tanto con auriculares Klipsch R6, como con unos Sony mdr1rbt. Como veran le sobra margen para mover lo que sea :shock:
Cuenta con dos entradas adicionales de microsd para ampliar la memoria.
Precio: $22.000
Incluye:
- Reproductor AK120
- 2 Fundas de cuero
- Dock de carga usb original AKS01 (Valor u$s150)
- Control remoto original IAA01
Specs:
General Specifications
Model AK120
Body Color Black Only
Body Material Aluminum
Display 2.4inch QVGA (320 x 240) IPS Touchscreen
Supported Audio Formats WAV, AIFF, FLAC, ALAC, APE, MP3, AAC, WMA, OGG, DSD
Sample rate WAV, AIFF, FLAC, ALAC : 8kHz ~ 192kHz (8/16/24-bits per sample)
Output Level L: 1.5Vrms + R: 1.5Vrms (Condition No Load)
DAC Wolfson WM8740 24-bit DAC (High-End Audio DAC) x2
Decoding Supports up to 24-bit / 192kHz Bit to Bit Decoding
Charging Interface Micro USB Type-B
Interface USB 2.0, OPTICAL IN/OUT, Headphone Out
Dimensions 2.33 ”(59.2 mm) [W] x 3.50 ”(89 mm) [H] x 0.57 ”(14.4 mm) [D]
Weight 5 oz (143 g)
Feature Enhancements Firmware upgrades supported
Audio Performance
Frequency Response ±0.02dB (Condition: 20Hz~20kHz) / ±0.2dB (Condition: 10Hz~70kHz)
Signal to Noise Ratio 113dB (1kHz 0dB, 24-bit 48kHz, No Load)
Crosstalk -128dB (1kHz 0dB, 24-bit 48kHz, No Load)
THD+N 0.0008% Typ (1kHz 0dB, 24-bit 48kHz, No Load)
IMD SMPTE 0.0005% (24-bit 48kHz, No Load) 800Hz 10kHz (4:1)
Output Impedance 3ohm
Clock source
Clock Jitter 50ps (Typ)
Battery
Capacity 2,350mAh 3.7V Li-Polymer Battery
Continuous Playback Time Up to 14 hours (Standard - MUSIC: FLAC, 16-bit, 44kHz, Volume 37, EQ Off, LCD Off)
Charge Time About 6.5 hours
Memory
Built-in Memory 64GB [NAND]
External Memory microSD (Max 64GB) x2
OS
Supported OS Windows XP, Windows Vista,7,8 (32/64bit), MAC OS X 10.6.5 and up
Link del fabricante para specs y mas informacion
https://www.astellnkern.com/eng/content ... de=SC11080
Dejo link de ml por si les sirve el pago con tarjeta y cuotas:
https://articulo.mercadolibre.com.ar/ML ... ock-rc-_JM
Se puede coordinar la entrega en Moreno, Villa Martelli o Nuñez.
dariohead
por dariohead » 20 Ene 2018, 12:54
Falto mencionar que conectado por usb a la pc funciona como DAC!
dariohead
por dariohead » 03 Feb 2018, 21:38
Bajando a $20000 para el foro
Enviado desde mi SM-N9005 mediante Tapatalk
dariohead
por dariohead » 28 Jun 2018, 15:35
Suspendida la venta. Este dolar mata upgrades : frio
dariohead
por marcos911 » 28 Jun 2018, 16:23
que lindo producto... no sabia de su existencia...
marcos911
  • Hasy 3 Usuarios identificados :: 1 registrado, 0 ocultos y 2 invitados (basados en usuarios activos en los últimos 5 minutos)
  • Usuarios navegando por este Foro: JulianLis y 2 invitados
