Vendo Oppo Sonica Dac
por Andik777 » 06 Feb 2018, 21:04
Hola a todos. Vendo Oppo Sonica DAC.
Un excelente aparato para disfrutar la musica de alta calidad.
El aparato es nuevo caja cerrada, con manual, cable de corriente y control remoto. 220V
Precio $32.000
SPECIFICATIONS
Designs and specifications are subject to change without notice.
General
Dimensions (W x H x D) 10.0 x 3.0 x 14.2 inches, 254 x 76 x 360 mm
Weight 10.4 lbs, 4.7 kg
Power Supply AC 110-120 V ~ / 220-240 V ~ 50/60 Hz
Power Consumption 30 W (operation), 0.5 W (standby)
Trigger Input 3.5 V - 15 V, 10 mA minimum
Trigger Output 12V, 100 mA maximum
Operating Temperature 41°F - 95°F, 5°C - 35°C
Operating Humidity 15% - 75% No condensation
USB Audio Input (USB B Type)
Input Format Stereo PCM, Stereo DSD (DoP v1.1 or native)
PCM Sampling Frequencies 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz, 352.8 kHz, 384 kHz, 705.6 kHz, 768 kHz
PCM Word Length 16-bit, 24-bit, 32-bit
DSD Sampling Frequencies 2.8224 MHz (DSD64), 5.6448 MHz (DSD128), 11.2896 MHz (DSD256), 22.5792 MHz (DSD512, native mode only)
Profile USB 2.0, USB Audio 2.0
Coaxial and Optical Digital Audio Inputs
AUX Audio Input
Input Impedance 10k Ohm
Maximum Input Level 2 Vrms
USB Ports (Type A)
Profile USB 2.0, mass storage only
Audio Format Support AAC, AIF, AIFC, AIFF, APE, FLAC, M4A, M4A (Apple Lossless) ALAC, OGG, WAV, WMA, DSF, DFF
Maximum Sampling Rate PCM up to 192 kHz / 24-bit, DSD up to 2.8224 MHz (DSD64)
Wireless Standard
Wi-Fi 802.11.a/b/g/n/ac
Bluetooth Bluetooth 4.1
DAC Performance Specifications
Specification XLR Output RCA Output
Output Level 4±0.4 Vrms 2±0.2 Vrms
Frequency Response 20 Hz - 160 kHz (+0/-2.4 dB)
20 Hz - 20 kHz (+0/-0.04 dB) 20 Hz - 160 kHz (+0/-2.4 dB)
THD+N at 1 kHz (A Weight, 20 Hz- 20 kHz) < -115 dB < -115 dB
Channel Separation > 120 dB > 120 dB
Signal-to-Noise Ratio
(A Weight, 20 Hz- 20 kHz) > 120 dB > 120 dB
Dynamic Range
(1 kHz -60 dBFS, A Weight, 20 Hz- 20 kHz) > 120 dB > 120 dB
Accuphase E370 ProAc Response D18 Lumin D2 Chord Epic Twin Wireworld Equinox 7
Andik777
por Andik777 » 08 Feb 2018, 10:14
Amigos foreros, a quienes les interesa el Oppo, pueden venir a escucharlo sin compromiso, ya que tengo uno en mi sistema.
Andik777
por Andik777 » 15 Feb 2018, 10:27
Sigue en venta.
Andik777
por Andik777 » 13 Mar 2018, 10:21
UP
Andik777
por Andik777 » 24 Mar 2018, 08:12
Nuevo precio $30.000
Andik777
por Andik777 » 02 Abr 2018, 16:02
Venta finalizada. Gracias por el espacio.
Andik777
por Andik777 » 28 Jun 2018, 18:04
Vuelve a la venta. Nuevo en caja cerrada.
Precio $ 35.000
Andik777
por Andik777 » 05 Jul 2018, 12:17
Nuevo precio $38.000
Andik777
por Andik777 » 20 Jul 2018, 00:12
Nuevo precio 1500 UD$ o equivalente en pesos.
Andik777
por Andik777 » 25 Ago 2018, 15:21
Nuevo precio 1400 UD$ o equivalente en pesos
Andik777
  • Hasy 4 Usuarios identificados :: 2 registrados, 0 ocultos y 2 invitados (basados en usuarios activos en los últimos 5 minutos)
  • Usuarios navegando por este Foro: Bing [Bot], masterjack1095 y 2 invitados
