NuPrime lanza la CDP-9
por Geezeth » 02 Oct 2017, 18:09
The NuPrime CDP-9 is a highly accurate CD player with an integrated high-end DAC and preamp. A powerful DSP-based decoder that provides all Red Book error-correction capabilities with master-clock control of the entire decoding system, thus lowering jitter significantly. The transport’s single speed minimizes vibration and unbalanced discs. The high-performance DAC, together with a selectable sampling rate converter for the digital output (up to 32bit/768kHz and DSD512) converts the CD format to either SPDIF at highest sampling rate or DSD format up to DSD512.
Features:
Highly Accurate CD Playback
• – A powerful ARM chip LPC2103F CD reads, writes and controls error correction
• – Philips SAA7824HL high-end laser reads/writes head control and decodes chips
• – Supports CD-DA CD-R, CD-RW
• – Algorithm reduces digital interference and jitter
A Reference Class Preamp
• – Advanced, FPGA-implemented, switched-resistor ladder network for controlling volume with a single resistor in the signal path at any volume setting
• – Individually adjustable volume on each input for precise source-level matching
• – Volume adjustments in 99 precise 0.5dB increments. Full microprocessor control with memory retention
Sampling Rate Converter
• – The sampling rate of any digital inputs, including CD playback, can be converted up or down between PCM and DSD, from 44.1kHz to 768kHz or DSD64 to DSD512
– The conversion is achieved by up-sampling to mega hertz before down converting to the targeted sampling rate with ultra-low jitter and distortion
Headphone Amp
• – High performance op-amp headphone amp
Compatible OS
• – Exclusive driver software for Windows
• – Standard driver software for Mac
Power and Mechanical
• – Low power consumption in Standby Mode
• – Available in black or silver anodized aluminum finish
http://www.nuprimeaudio.com/product/cdp-9/
(MSRP $1695)
por soniq » 03 Oct 2017, 19:55
Está bueno !
Puede usarse como DAC o lector, incluyendo un pre.
Una pena que no sea reproductor de red, estaría todo en uno.
Por lo que vale, pienso que podrían haberlo implementado.
por leepancho » 03 Oct 2017, 20:36
no es un producto barato... que chip usará para dac ?
Para mi gusto, falta una entrada usb denlantera para leer audio de disco portatil ...
leepancho
por soniq » 03 Oct 2017, 21:11
leepancho escribiste:no es un producto barato... que chip usará para dac ?
La tiene atrás, son productos bastante estéticos y minimalistas. Es media server pero no media player.
por Musicfont » 03 Oct 2017, 23:18
Poderoso el Chiquitin...
Musicfont
por Fadragani » 04 Oct 2017, 20:43
Tendra SABRE ? como utiliza Audiolab.
Fadragani
por Toberius » 05 Oct 2017, 21:24
soniq escribiste:Una pena que no sea reproductor de red, estaría todo ...
Coincido, ahora..... taaaanto les cuesta dar soporte de red :evil:
Chord SPM 1200
Celestion SL6Si
Marantz 2265 upgreado JB
Ortofon T30
Oppo BDP 105
Linux / Gentoo
Toberius
Volver a Audio
